Bravo Trim Pump
My stbd drive was moving up and down really slow so I changed the trim cylinder end caps as they can corrode and pinch the trim ram. Now, the drive goes up fine but still comes down slowly. The pump makes an audible sound difference in the down direction which is a lot different than the up direction that I can hear. Also, the down direction on the other drive sounds a lot different.
I ran the drive up and down about 20 times to clear the air out of the system so it shouldn't be air.
Seems like the motor is OK?
Can the hydraulic pump be the issue?
How about the down check valve?
Any help would be appreciated.
Long time cult member.
Did u check all the wires going to that pump,,,,and the selinoid???
Yep,,,,,if its the same ,,,,just buy a used good pump on e-bay.
I have seen them for around 100 bucks ,actually i bought one a year ago and still works perfect.
i also had the same problem ,,,,but it was the up pos. after i replaced the o-rings in the trimmcylinders it was ok,,,,but u sayd u did that already,,,,what happens is the fluid bypasses the o-ring and makes the pump sound diffrent.
U may whant to check that again,,by switching the high and low side then u see if the pump now makes the funny noise in the up pos. !!!!
Thanks.
I put a seal kit and a new trim cylinder cap in each trim cylinder so that should be OK like you said.
So if I switch the lines on the pump and the noise switches to when the motor is running in the up direction the problem may still be in the rams. If the noise stays on the down side with the hoses switched it's the pump, right??
Thanks.
Rambunctious
04-22-2003 06:37 AM
