info on lower bravo drive >
Old 02-06-2009 | 10:56 PM
Question info on lower bravo drive
my bravo one has a lower water pick up by the prop and skeg. do them come like that stock? im just curious because it doesnt have the normal water pick up on the side like most lower units. are they better since u can run drives out more?
TheFever29 is offline
Old 02-06-2009 | 11:19 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
My '99 stepped hull has the lower water pickup. My '94 non stepped had the side pickups.
US1 Fountain is offline
Old 02-07-2009 | 01:37 AM
Do you mean it has the water p/u holes on the front of the bullet only??????
Its a LWP(low water pickup) drive. They are used on many step hull boats and boats with a high x dimension.
Better????? no, but necessary in some cases.
They also suck up sand very easily in shallow water.
Griff is offline
Old 02-07-2009 | 07:32 AM
MarkDonzi's Avatar
I had a boat with SWP in the nose cone, Pain in the A$$ in shallow water would plug with sand very easily.
MarkDonzi is offline
Old 02-08-2009 | 09:57 AM
Default Fix for low pick up
We have run across this in the past as boating on the Chain in our area has some shallow areas. We simple took a standard pick-up Bravo lower made a template and drilled holes for the standard pick-up's makes a big differance and only takes about a half hour or so. Make sure that you chanfer the holes toward the front of the drive. We use a rattle can to cover the area back to black. Works great.
RBeyer is offline
Old 02-09-2009 | 08:23 PM
thanks for all the replies. appreciate it all. where i run the water is very very shallow but no problems with sand getting clogged yet.
puder
6
02-23-2011 07:05 AM
Dave1972
6
03-30-2009 04:06 PM
aTX427
Swap Shop
20
03-22-2009 09:53 AM
Smarty
13
06-17-2007 11:08 AM
mez
Drives and Lower Units
2
04-28-2007 10:45 PM
