-   -   Bravo to XR (https://www.offshoreonly.com/forums/drives-lower-units/204499-bravo-xr.html)
Sledge Hammer 03-08-2009 09:36 PM
Bravo to XR
If you change to an XR toi handle additional horsepower, do you need to change the gimble and transom assembly?
1BIGJIM 03-09-2009 06:45 AM
When I changed mine, I had to put spacers in the 2 rams to limit the up travel and make sure you have the RED dot gimble bearing.
Thats it.
outlawinil 03-09-2009 08:00 AM
In the process of doing the same. What kind of spacers to limit up travel?
1BIGJIM 03-09-2009 09:42 AM
Read this thread it explains everything:drink:
http://www.offshoreonly.com/forums/d...swap-help.html
outlawinil 03-09-2009 09:50 AM
You mean the spacers in the slotted hole on the outdrive where the cylinder connect? Moved them to the front of the hole?
1BIGJIM 03-09-2009 12:16 PM
This is a pic off Bams webside. To install the spacers you take the end caps off the rams and push them on and put the caps back on. I made my own tool to get the caps off.
If you price the mercruiser tool you better be sitting down.
http://www.mercruiserparts.com/showS...sp?pn=862540A2
outlawinil 03-09-2009 12:45 PM
So if you were swapping outdrives going from a bravo 1 to an XR could I also just swap trim cylinders. Keep the trim cylinders with their respective outdrives?
Thunderstruck 03-15-2009 07:49 PM
Can you modify the prop to accept the bigger XR propshaft????
Jeff P31 03-15-2009 09:02 PM
Just change the hub in the prop to fit xr shaft. :ernaehrung004:
Thunderstruck 03-16-2009 07:01 AM
