-   -   Pressure Testing a Bravo (https://www.offshoreonly.com/forums/drives-lower-units/206610-pressure-testing-bravo.html)
DesertRage 04-16-2009 07:46 AM
Originally Posted by Mr Gadgets (Post 2845162)
Here is what I use to psi test. I have a brake bleeder vac pump I use to vac test them..
Mr Tryce,
How much vacuum do you apply?
Thanks.
Mr Gadgets 04-16-2009 08:43 AM
It has been a while since I vaccum tested. I mainly psi test and have not had any issues with water infiltration if they hold psi. With the brake vaccum tester, I think I would pull on it till the guage was in mid range. I have to see the gauge to tell exactly..
