TRS Drive Spacer
Old 04-17-2009 | 01:00 PM
Rookie's Avatar
I did a little research on you boat after posting to this thread. It is a unique little boat, and the Max horsepower rating from the factory is 500, but one was never built with that much HP. Find out how true the bottom is, and test a bunch of different props. There are a few different builders that put the TRS setup in small boats such as your and had some good handling boats. Just adding a Bravo might or might not fix your problem. (There are Bravo boats out there that do porpoise it is not a fix all solution, and my 30' Twin porpoised like a B!TCH!! with the wrong props)
Enjoy your ride it is something different!!
Rookie is offline
