BMAX parts and help >
BMAX parts and help
BMAX parts and help
Old 04-23-2009 | 01:59 PM
Mr Gadgets's Avatar
Charter Member #601
Yes they did...
Mr Gadgets is offline
Old 05-27-2009 | 06:07 PM
All 7 bolts came out ? or did the housing break?
waconda is offline
Old 05-27-2009 | 08:36 PM
Actually it happends all the time with the B-MAX's.
a buddy just lost his lower in Marathon last week during a race,,,,the nuts just vibrate off and then its a free fall for the lower ?!
DareDevil is offline
Old 05-28-2009 | 12:16 AM
Strip Poker 388's Avatar
Rob
Originally Posted by endeavor1
The back screw broke off in the upper, the four studs in the upper are stripped now and who knows what the bottom looks like. Won t know anything till the divers bring it up. What could have caused this????? Dean thought a possible catastrophic failure caused it to blow straight down, but thats a tone of force to cause that
The studs or the upper housing threads striped?
I got one back once and he left of the thin washers off,the nuts dug into the case,I went to put the washers on and one stud was totally striped, so that meant who ever put it together knew is was striped and probably said Fk em.
sounds like something pushed it off? Panther had one push the top cap off.Ya got the back cover off, look in there and pray
Did he rebuild the top?
Rob
Strip Poker 388 is offline
Old 05-28-2009 | 07:02 AM
The back screw broke off in the upper, the four studs in the upper are stripped now and who knows what the bottom looks like. Won t know anything till the divers bring it up. What coulds have caused this????? Dean thought a possible catastrophic failure caused it to blow straight down, but thats a tone of force to cause that
Post pics when you get it back.
waconda is offline
Old 05-28-2009 | 08:52 AM
Guys, i appreciate all the help. Dean is "supposed" to call me back today and figure out what he is going to do about this. I personally put the lower on and can promise you all that the studs werent stripped. Also, 20 hrs ago, i had the upper and lower rebuilt on the other side and put it together and its still running fine. Hopefully there is no dammage in the upper also in this drive. What causes BMAXs to do these things. I'm considering just making this a #5 boat and being done with all the bravo style problems. Any thoughts....
endeavor1 is offline
Old 05-28-2009 | 10:03 AM
Panther's Avatar
Frank's Marine Service
For whatever it's worth I've heard and seen this happen on the Mercury Bravo ITS drives.... It happened to a friend in a poker run...no warning etc...just blew off the back of the boat.
Panther is offline
Old 05-31-2009 | 04:07 PM
After speaking with Dean at the Bravo Shop, He told me that the locks on the upper gear had came loose magically and pushed the lower off the upper drive case. We are in the process of working something out because I dont buy the "MAGICAL" BS line. Ill keep everyone posted as to what happens. Also, Im going diving next week with a group to see if we can locate the lower and my 15 minute old prop that was on it
Old 05-31-2009 | 08:09 PM
Panther's Avatar
So the lock c-locks on the clutch shaft came out and shot the clutch shaft down and pushed the lower off the drive?????
only way I could see that happening is from loose tolerances in the clutch pack in the upper or the clutch shaft ball bearing cluster bloke, otherwise you have to compress the upper gears quite a bit to get the clips loose.
that f'ing sucks!! Let use know how you make out with replacement.
Panther is offline
Old 05-31-2009 | 10:47 PM
Rob
Big bird did it,wait till the cookie monster eats it
That cookie monster is a sneaky little bastard
