Gear Ratio Questions >
Old 05-02-2009 | 10:09 AM
Default Gear Ratio Questions
I am rebuilding a 1987 24 foot Baja Sport. The boat weighs about 4500 pounds. I am building a 540 that i expect to be between 700 to 900 HP. My question is about the outdrive in particular the gear ratio. Do I need to stick with the 1:50 ratio? What advantages or disadvantages would going lower or higher have. Your opinons would be a big help in educating me. Thanks
mecelec is offline
Old 05-02-2009 | 11:23 AM
If you were 700-750 hp, then stick with a 1.5. More than that and you will have more prop options with a 1.36.
Griff is offline
Old 05-02-2009 | 12:46 PM
I guess a 1:25 would be going too far my application?
mecelec is offline
Old 05-02-2009 | 02:17 PM
You definately won't need a 1.25.
BTW, That hull was never designed to handle the speeds with that much power. You better have full hyd steering and K planes to even attempt it.
Griff is offline
Old 05-02-2009 | 05:34 PM
articfriends's Avatar
I'd stick with a 1.50,its rare for a single to even pull a 32 pitch so I doubt you'll run out of gear,I haven't yet,Smitty
articfriends is offline
Old 05-03-2009 | 09:57 AM
Thanks for the input. I have never built a boat like this and I am trying to eductae myself as I go along. The info is greatly appreciated and helpful.
mecelec is offline
Old 05-03-2009 | 01:00 PM
Vinny P's Avatar
I hate the winter!!
700 to 900 hp is a world of difference. Dont think you will see 900 hp from a 540 unless you go forced induction. As`was said, tabs, steering, drive first.. then build power.
Vinny P is offline
