Impact damage
Would impact damage cause the u-joint coupler to explode on a bravo boat?
I would think it would break a lot of other stuff first, like the engine coupler or drive gears.
Originally Posted by Griff
(Post 2857677)
what does the prop and prop shaft look like, you may have suffered a upper failure causing the other damage, is the input shaft twisted?
There is a impact point on the leading edge of the nosecone & skeg along with a nice blue transfer line, a spot & the blue on the mid-section where whatever kicked up into it.
Everything else looks to be ok. |
if it hit hard enough to knock the drive up at a high rpm, it could have caused the u-joint assy to fail, but not sure on the gears, I would have expected prop damage. what speed and rpm where you at when it failed?
About 45-50 mph, 3000-3500 rpm or so. Hadn't even hot-rodded it yet for the year. It was the 1st outing, just warming up the oil.
well I would say that if everything was fine til then, it was probably impact damage.
Originally Posted by hoozeyurdaddy
(Post 2857910)
got insurance, sounds like impact.
good luck larry |
