Konrad Marine Speedmaster Conversion Special! >
Old 05-05-2009 | 07:51 AM
Biggus's Avatar
Default Konrad Marine Speedmaster Conversion Special!
Spring special on the Konrad 540 PRS III (SSM IIII) conversion kit.
The Konrad PRS III is a direct bolt-on drive unit for the Merc Speedmaster III. This system retains the existing Speedmaster transom assembly. All that's required is swapping out the SSM drive bell and installing the Konrad bell (included w/ new bellows) into the SSM gimbal ring.
Benefits include:
Almost 2" higher prop shaft height
Heavy Duty upper gear housing/input shaft
Wing plate steering cover
Next day parts availability in most cases.
Spring special $9995.00
Feel free to contact me directly for a dealer near you.
Kurt 715-410-0735
Attached Thumbnails Konrad Marine Speedmaster Conversion Special!-prs3_port_profile2%5B1%5D.jpg   Konrad Marine Speedmaster Conversion Special!-prsiii_star_angle%5B1%5D.jpg
Biggus is offline
Old 05-05-2009 | 03:16 PM
Biggus's Avatar
Here's a few pics of a SSM Cigarette Top Gun converted by the talented crew at Doller Offshore.
Biggus is offline
Old 05-07-2009 | 08:52 PM
activemike's Avatar
What is the Hp rating & warranty on these drives. Will these work with or replace new XR drives.
activemike is offline
Old 05-08-2009 | 06:07 AM
Biggus's Avatar
They are rated to handle up to 800 hp. Warranty is one year w/dyno sheets provided.
This particular Konrad model is designed as a direct replacement for the Mercury Racing Speedmaster III.
The Konrad ACE package is designed for Bravo boats. It includes an extension box to house the BAM transmission.
Feel free to call me anytime for more info. (I'm the factory rep for Konrad)
Kurt 715-410-0735
Biggus is offline
Old 09-21-2009 | 11:37 AM
Biggus's Avatar
TTT
I happen to have a pair of factory reconditioned Konrad units avalable if interested.
This is a fantastic alternative for owners of SSM III boats, they bring the propshaft up 1.5" and now you can run much more reasonably priced Bravo style props.
Kurt 715-410-0735
Biggus is offline
