B-Max
They do, I run about a 1/4 to1/2 inch in the bottom,I have to have a puke tank for the rez.The extra bottles ya see I sent to Panther he said they all had cracks in the bottom,they still leak just like the old style merc's.Dean has them for 50.00.They need to be that big also,Could be bigger.Also I think one reason for vented is the new style cases are so porous,even with the aircraft type sealer in the inside of the drive that it would build up pressure and make it more prone to leak.
I had a old B Max bottle for a puke tank it leaked to,I am looking for another style bottle to use.small
The GET REAL bottles are nice looking,BUT I had a problem with one leaking,it was machined a few thousandths off,leaking at the lower oring. He redid that one, then the bracket started rattling it had slack in the mounting bracket,you could hear it at the helm,looking at it was shaking bad. Get Real would never fix it,wouldn't return calls,I must of called for months, Gave up and I put a set screw in it to stop the rattle.
