bravo 1 propels at idle speed only
I have a 1988 merc 7.4L with bravo 1 outdrive. Everything runs fine around 2,000rpm 7.5 knots.
When I try to throttle up, the engine revs way up and the propeller stops moving the boat.
I've replaced the hub in my propeller several times and I have finally decided that was never the problem.
What else could be causing the loss of power transmission?
I've had good days when I can get all the way up to WOT, on plane, no problem and other days it won't push past 2,000rpm
i dont get the 6 hrs labor listing???. you already listed...pull the engine for $200. once the engine is pulled, it's only 6 or 8 bolts to change the coupler. i can see if you listed re-install engine for $200, but where does the 6 hrs come from ?
