Do bravo x drives require red dot bearings >
Old 05-26-2009 | 06:59 PM
Default Do bravo x drives require red dot bearings
I am getting conflicting stories here. I am switching from bravo three to bravo three x's. Knowing that the difference is only in the gear assembly, same drive assembly. I am being told that the bravo x drives require the red dot gimbal bearings. A call to mercury both Wisconsin and Oklahoma yields that they do not use red dot bearings in bravo/ or bravo x assemblies being they use the same transom assemblies, only in the xr series drives with the hp assemblies. Which person is correct? Any help would be appreciated.
rockstar342 is offline
Old 05-26-2009 | 07:42 PM
Mbam's Avatar
Offshoreonly Advertiser
Red dot is mandatory, the U joint is differant. That being said they are standard on all Bravo transoms starting @ serial 0M, but check yours regardless.
Mbam is offline
Old 05-26-2009 | 08:18 PM
put the red dot in,its not hard to do and not very expensive,JUST DO IT.
mike tkach is offline
Old 05-26-2009 | 08:40 PM
Elite Marine's Avatar
You just missed a great sale by BAM on Ebay!! $ 35.00 each.
Thanks Marc
Elite Marine is offline
Old 05-27-2009 | 10:33 AM
Transom assemblies and drives are both 2007 model year. So is it safe to assume they have red dot bearings and are ok?
Old 05-27-2009 | 12:16 PM
Mbam's Avatar
Yes, but you know what happens when you assume
Mbam is offline
Old 05-28-2009 | 10:26 AM
There needs to be a relief on the inner race I think. This is so the larger u-joint clears the bearing. Make sure it is there. Even though you should have the correct bearing in there, I've heard of it being installed backwards at the factory (which wouldn't matter for the standard drive), but would if you upgraded to the larger joint.
ACrooks69 is offline
