trs rotation?
Old 06-26-2009 | 03:44 PM
Panther's Avatar
Frank's Marine Service
Originally Posted by picklenjim
I always heard the RH drives were stronger than the LH. In the LH the drive shaft is end to end turning the prop shaft which would create more bind on the propeller end,more twisting load. RH turns the prop shaft from the center of the shaft so the support is evened out on both ends of the propeller shaft.
It's the opposite... LH Drives have the drive gear in the housing behind the vertical shaft. The RH Drives have the gear ahead of the vertical shaft and the thrust force is pushing against the carrier.
In rough water and high HP applications the torque trys to separate the gears and on the RH drives the carrier moves because there's a crush collar between the spanner nut and the carrier and it can flex and skew the gear lash, resulting in gear failure.
Panther is offline
Old 06-26-2009 | 05:23 PM
Mbam's Avatar
Offshoreonly Advertiser
Panther - not exactly true. The crush (load ring) is actually at the forward end of the carrier. The load to the rear is 100% carried by the spanner nut. There is nothing pushing the carrier forward. I will agree on the RH drive the gear load is trying to push the carrier out.
If the housing is corroded/stripped it can pop the nut out - carrier, shaft, prop and all.
The LH drive has the gear forward against the bullet so you won't pop the carrier out so it is stronger in that respect.
In either direction I think the prop shaft is stout enough so deflection & twist are not an issue.
Actually I've been doing this since the TRS came out and I don't remember there being an pattern as to which is more likely to fail except for the housing issue.
Mbam is offline
Old 06-26-2009 | 06:29 PM
RH drives seem to be the ones breaking lower gears under high HP applications.
Might be cheaper to have a reverse rotation motor and run 2 LH drives!
MILD THUNDER is offline
Old 06-27-2009 | 08:48 AM
Panther's Avatar
I hear ya and you're much more experienced than I but every TRS RH drive that I solid shimmed the carrier lasted longer. My thought was it stabilized the carrier better than the crush collar.
My personal experience breaking a few TRS's was 1 LH and 3 RH's and once I solid shimmed it I didn't break any more RH's for a long time and then I sold the boat. Overall I still liked the drive though!
Panther is offline
Old 06-27-2009 | 09:24 AM
Originally Posted by maxineis
Yes, it is a 1978/ 20 footer with a stroked small block, 383 with all the goodies, hits 70 plus. Purchased as a project and re-powered it, drive got stolen last summer and i replaced this summer. This was a 3 year project , was an interesting learning curve and its a hit on the lake being piloted by a women. lol.
Also the answers I got here were very helpful in buying a replacement that worked. I thank everyone who posted on this topic.
maxine
http://images.ibsrv.net/ibsrv/res/sr...coolcowboy.gif
A women who rebuilt her own boat, now that's hot!!
502ss is offline
Old 07-12-2009 | 05:52 PM
Hang Time 27's Avatar
Yes Sir on that one!!
Here is the best cure for that RH -LH issue though !!!!
Hang Time 27 is offline
Old 07-13-2009 | 07:30 AM
One of the problems with TRS gear failure is people are running high HP and speeds the lower unit is comming up and out of the water and they are like suface riding the drive. The TRS only has one vertical shaft and was not desighned to be run that way. The vertical shaft starts to whobble and its all down hill from there.
Clustergear is offline
Old 07-14-2009 | 04:06 PM
Yea, I got 3 sittin in my shed that either rolled, slid, or bounced all the way down the hill. Anybody want 'em??
I think they are great pieces of "farm equipment" for "plowing along".........
