Alpha prop size
Old 07-16-2009 | 07:34 AM
Default Alpha prop size
Anyone know if a 15 1/4" prop will fit on an Alpha?
rainmann is offline
Old 07-16-2009 | 10:22 PM
Yes it will, my buddy has a 21ft 1987 Scarab 1 with a 260hp 350 with a alpha and a 21p mirage plus on it.
Erik
crapr6 is offline
Old 07-17-2009 | 09:11 AM
Registered User
Maximum prop diameter on an alpha is 15".
Erik
A Mirage plus is a 14-3/8" to 15" dia prop.
Marco
Holeinthewater is offline
Old 07-17-2009 | 10:20 AM
I am running a 27P x 15 Hydromotive on my Alpha. It looks like a 15 1/4 would fit, but would not leave you much room for error!!
DKerns is offline
Old 07-17-2009 | 01:54 PM
Registered User
Mercury recommends a max of 15" for the Alpha. If you run something larger and the blades should happen to flex forward, from the thrust imparted on them under load, things may get ugly.
Marco
Old 07-17-2009 | 06:37 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Default prop
I'm running a A 15 1/4 BY 30 on my stinger with a alpha one gen one.No problem. JOHN
Fenderjack is offline
