TRS / Borg-warner?
Forgive my ignorance. This is my first Offshore boat and first boat with a tranny. I am getting ready to sea trial our boat 1979 Carrera with a TRS and Borg Warner. My question is boat has been sitting for a long time. I plan on replacing all fluids before sea trial what else should be done and what fluids do you suggest.
I would recommend starting it on the trailer to be sure it's going to run when you get it to the ramp.Take a garden hose and wrap duck tape around it a couple inches from the end until you have a diameter of 1 1/4 ".Disconnect the end of the hose going to the through hull water pick up.Shove the garden hose in to the water pick up hose and tighten the clamp in the area the duck tape is in.Have someone turn on the water slowly.Start the engine.When it starts have them turn the water on FULL.Do not run engine with out water connected. Let it run a while to confirm it's going to run correctly.Watch your gauges.Run the drive up and down a few times to make sure the trim works.With drive all the way down slip in to forward for about 10 seconds.Then return to neutral and then try reverse for about 10 seconds to be sure tranny is working correct.Take it out and have fun.
No actual drain plug on those trannys. If you have the model with the screen it may need to be cleaned.That's the fluid going to the trans cooler.
Would I be Better off to pull the lines and drain? It is kinda tight in there being it is only 24' and I go a little over 6'. If that is the way it needs to be done I will find a way. Should I put a new tranny coller on?
