TRS Lower....don't wanna phuckitup >
Old 08-24-2009 | 11:18 AM
Originally Posted by commandersander
Ummm....yeah....dead serious.
There are areas that you can't get to when everything is together. I am really picky about this kind of thing, and I would hate to put a grand into paint and hardware and still have it look like I did it the "easy" way.
It works perfect, but again.....not big on short-cutting anything. My mantra is "what you do is a direct reflection on who you are. If you can't do it well, what does that say about you?"
Not "you"....you is a general term
Good luck. I would just wait until it was time for a rebuild and then do all the fancy paint work
jeff1000man is offline
Old 08-24-2009 | 10:25 PM
spazboz's Avatar
Default TRS Drive Painting
Good luck with your project, the results can be very rewarding. Here is a before and after from the last refinish I did.
Nick
spazboz is offline
Old 08-24-2009 | 11:30 PM
Audiofn's Avatar
Charter Member #232
Just remember if you get paint on the mating surface you will change your shim values enought that you should re shim the drive.
Put your best foot forward!
Audiofn is offline
Old 08-25-2009 | 10:46 PM
Looks awesome. Do you have a code on the silver?
Good point about the mating surfaces. I'll have to make sure to clean it back to raw aluminum.....
commandersander is offline
