B-Max
Old 08-25-2009 | 08:36 PM
Default B-Max
How much speed loss did people see when they changed from an xr bravo1.5 ratio to the b-max 1.3 ratio?
dennis r is offline
Old 08-26-2009 | 07:19 AM
If you don't reprop it you will loose a bunch, but with the correct prop you will be back where you were before or more.
waconda is offline
Old 08-26-2009 | 08:43 AM
I went from a 30 pitch with 1.5 xr at 105 mph to a 24 pitch 1.3 b-max at 96 mph
dennis r is offline
Old 08-26-2009 | 09:44 AM
Mr Gadgets's Avatar
Charter Member #601
You did try a 26 also didnt you?
Mr Gadgets is offline
Old 08-26-2009 | 11:53 AM
yes I did it went 98mph at 5700 rpm
dennis r is offline
Old 08-26-2009 | 12:13 PM
shortie or standard???
endeavor1 is offline
Old 08-26-2009 | 12:36 PM
The xr was a standered and the b-max is there cresent lower
dennis r is offline
Old 08-26-2009 | 07:57 PM
-5mph
Back4More is offline
Old 08-26-2009 | 08:06 PM
I meant to ask is the BMAX a standard length or -2. I switched to standard length from -2 to see if i can get my BT to hook up a little better and be easier on the drives. I know that the BMAX takes a lil xtra hp to turn, so on a complete guess id say a couple mph lost anyway.
Old 08-27-2009 | 04:37 AM
The b-max is not a shorty
dennis r is offline
