Help me understand counter rotating props? >
Old 10-01-2009 | 03:50 PM
So to sum it up....
Alpha- only makes clockwise rotation drives. Therefore you could not. Swap these drives from side to side. Which in turn means alphas may not last as long and require rebuild sooner?
Bravos - make a drive that is capable of runnig clockwise and counter clockwise at high rpm's....what makes one rotate clockwise or counter clockwise is the connection to the shifter fork in the rear of the drive... They can be swapped from side to side. The props are also side specific.
This correct ???
FuelinAround is offline
Old 10-01-2009 | 04:52 PM
Thank you everyone for your knowledge. From this I now know the guy that told me it is common to have a counter engine with a counter outdrive is full of BS. I also learned that you cannot just switch cables on an alpha and run it in reverse - I have to purchase a counter assy. Last, neither of my engines are counter rotation, phew! Now to find a unit and prop... A wise man once told me that BOAT stands for Bust Out Another Thousand and boy was he right!
spunner is offline
Old 10-01-2009 | 05:03 PM
Originally Posted by kyboy1020
So to sum it up....
This correct ???
They do make a counter rotation alpha,
it uses a special lower unit.
Bravo's, don't care.
JaayTeee is offline
Old 10-02-2009 | 02:02 AM
So to sum it up....
This correct ???
Alpha's come in both RH and LH rotations now. Originally, I think they only had RH. On a lot of older Alpha twin engine boats, they had standard RH drives on both sides. They can be switched from side to side. They will still turning the same direction. Rebuild time is not a factor.
Bravo's can spin either way. If you spin it RH, it puts downward pressure on the upper gears. If you spin it LH, it puts upward pressure on the upper gears and top cap. They can be switched side to side. You can also change rotation by reversing the cable connections at the shifter and swapping props from side to side.
Griff is offline
