Transum thickness
Old 10-10-2009 | 01:08 PM
Thanks Griff, my plans may be changing anyway. I just gave a good inspection of the transum and motor mounts. The lower part of the cutout on the transum is a little soft. I had the engine out a few years ago and it had resign around the cutout. I noticed a little water in the bilge this summer. I also noticed the gel coat around the transum down low is cracking. The lag screws on one motor mount have loosened up. I may need to pull the engine this winter and beef up the motor mounts. If the transum looks like it needs repair I may just have the hole cut out 3" higher. That would put me at 5".
jeffswav is offline
Old 10-10-2009 | 01:42 PM
If the transom looks spongy on bottom I'd be looking at stringers as well. If that lag pulling out is any sign you may have a bigger project ahead of you. I know a few older Baja's that had similar rot issues.
I SURELY hope this is not the case but I'd inspect it very well before setting motor back in.
Irishtornado is offline
Old 10-10-2009 | 01:52 PM
While your at it do away with the lags and through bolt everything.
jdub is offline
Old 10-10-2009 | 02:01 PM
Couldn't agree more. Sandwich the stringer between 2 pieces of 1/4 or 1/2" aluminum with one being a L bracket with the mount stud attached. It's how they did the newer Baja's. I'll take some pics of mine for you being the motors are out.
Old 10-11-2009 | 09:40 AM
Thats exactally what I will do with the mounts. I am going to have them made to wrap around the stringer. I have not broke the news to the wife yet. I will know more when I get it apart.
jeffswav is offline
Old 10-11-2009 | 09:48 AM
Don't tell her anything.....just say you want to "freshen up" the bilge with some new paint
jdub is offline
