Imco SCX
Old 10-28-2009 | 12:06 PM
2112's Avatar
Originally Posted by johnlomant
Yes it will
Do they provide a upgraded input shaft and u-joint assembly or do you swap over the merc stuff?
2112 is offline
Old 10-28-2009 | 12:26 PM
Mr Gadgets's Avatar
Charter Member #601
I was misinformed about the weight of the SCX.. more like 185lbs.. Sorry for that.
Mr Gadgets is offline
Old 10-28-2009 | 02:03 PM
is that with the scx lower?
dennis r is offline
Old 10-28-2009 | 08:56 PM
Mr Gadgets's Avatar
Charter Member #601
That is a complete SCX drive, around 185#. What does your BMax weigh Dennis?
Old 10-28-2009 | 09:33 PM
Strip Poker 388's Avatar
Rob
Talking
Originally Posted by CB-BLR
The helmet kit is about $850+
You also need a 20 oz drive reseviour which from IMCO is about $400 because the drive holds 5 quarts, and the reseviour needs room for oil expansion.
I think this drive is really the solution for broken Bravo's.
It also has a built in oil cooler in addition to the drive cap cooler.
Chris
The B Max has a big expansion ,I have a puke tank for the oil reservoir.I got the Get Real rez it was too small and was not machined correctly,It took 6 months to swap out the first set that was leaking.the second set rattled in the bracket,you could hear it at the helm it was so loud,POS get real said they would take care of it,FBS!! I fixed it myself
Amsoil didnt like me calling aireation.ok it foams
Strip Poker 388 is offline
Old 10-29-2009 | 04:40 AM
Heavy I don't know but I bet it is up there
dennis r is offline
Old 10-29-2009 | 04:50 PM
2112's Avatar
How did you fix the rattling Get Real reservoir? Other than that, were they OK?
2112 is offline
Old 10-29-2009 | 05:22 PM
Rob
I put a set screw in them.even being small it stands out. They look great,I just need a bigger size ,I only run about 7/16 of oil level in them.
Old 10-29-2009 | 07:59 PM
Will the SCX drive except silent choice exhaust?
mudslide is offline
Old 10-29-2009 | 08:06 PM
CB-BLR's Avatar
Chris
No
CB-BLR is offline
