Imco SCX
Old 10-30-2009 | 04:17 PM
  #41
Originally Posted by Mr Gadgets
UD,
a different input shaft is used on the ITS. It is the Merc ITS input shaft, I believe. Add a couple hundred dollars for it above the standard setup.
Options include color, (silver, black) propshaft 1 1/4" or 1 7/16" Hub comes with it.
You will need a new helmet, reservoir, and the drive. If your motor won't idle down to around 800rpm.. you can install a shift interupter switch.
Thats about it. Like I said they are looking at the ITS trim indicator at this time. They should have something in the near future.. You will probably have to use their Gimbal ring to accomadate the trim sender setup?? Not a bad idea to install their HD gimbal ring..
Hope that helps.
Dick
No problem the 600s idle at 700 I will have to use the merc gimbal ring because the steering connects to it with the ITS setup. Got mechanical trim indicators so if the electric ones don't work not a big problem. I like the idea of using #6 props so I can stop throwing the bravo ones. This boat has a 22 1/2 X dimension which has the props surfacing.
mudslide is offline
Old 10-30-2009 | 08:12 PM
  #42
2112's Avatar
+1 on the ITS with Mechanical trim sender.
Do they (IMCO) have an ITS specific Gimbal ring?
I would want to stick with Bravo Props due to cost. Makes it much more palatable to keep multiple sets for different conditions. Aren't the SSM props for surface piercing drives only?
2112 is offline
Old 10-30-2009 | 08:50 PM
  #43
Vinny P's Avatar
I hate the winter!!
I ordered my SCX upper today through MrGadgets. I am going to mate it to my SC lower. I cant wait to see what this thing looks like.
Vinny P is offline
Old 10-31-2009 | 09:09 AM
  #44
Airpacker's Avatar
Default looks like this
SCX upper / SC -1 lower
Airpacker is offline
Old 10-31-2009 | 03:36 PM
  #45
Mr Gadgets's Avatar
Charter Member #601
They are working on a way to use the trim stuff that Merc has on the ITS. Not sure if they will end up with a special Gimbal ring or not. They just started looking at it this past week.
The idea is to run the SCX lower, it is -2".. Getting close to surfacing on some boats, maybe. If that is the case the less of the lower in the water the better.
But the Hub that comes with the 1 7/16 shaft will fit the Bravo props with the square hub. So you pop out the Merc hub and slide in the Imco one and on to the new lower..
Lot of options to fit what ever might be the case.
Mudslide,
Not sure what the #6 prop uses for shaft and spline. I will have to check and see. I try to stay away from those expensive props, so I have no experience with them.
Nice Airpacker!! Makes me want one also..
Dick
Mr Gadgets is offline
Old 10-31-2009 | 03:47 PM
  #46
CB-BLR's Avatar
Chris
Why cant I see the picture of the SCX... all I see is a small white box with a red x in it?
Chris
CB-BLR is offline
Old 10-31-2009 | 04:26 PM
  #47
2112's Avatar
Dick,
My main concerns with the ITS are the Tie bar attachments (I would like to use my MM, center to center bar) being able to use my existing 2" short sportmaster bottom and replacing the final weak link, the stock ITS Gimbal ring.
My next concern is if there is any affect on handling due to the extra 150 lbs way out back?
2112 is offline
Old 10-31-2009 | 05:14 PM
  #48
Strip Poker 388's Avatar
Rob
Chris
It prob runs out of bandwidth,then comes back up.guessing
Strip Poker 388 is offline
Old 10-31-2009 | 05:43 PM
  #49
2112,
Mudslide,
If you are interested Mud, I can shoot you a price, just pm me.
Dick
Dick,
Imco offers the #6 shaft for a option with the SCX lower.
01-3446 Prop Shaft #6 Prop Shaft #6 $766.00
The reason I want these props because my boat likes to throw Bravos and it is not from running in big water. I run mainly in rivers and small lakes. Not the great lakes. So thats why I want #6 props already throw 5 6 blade bravos (3 Herings and 2 Throttle Ups) thats not cheap either. Bravos aren't made to be surfacing props.
Bob
mudslide is offline
Old 11-01-2009 | 09:24 AM
  #50
Mr Gadgets's Avatar
Charter Member #601
I see that in my price list Bob, a difference of $124.00 list. I will check to see what the cost is to step up to them.
Dick
