TRS with merctrans engine removal >
Old 12-10-2009 | 08:52 AM
Default TRS with merctrans engine removal
Does anyone know if you can remove te engine without removing the drives or transmission? I just want to remove the engine so that I can rebuild and pit it back without messing with the trans or outdrive.
olmako20 is offline
Old 12-10-2009 | 11:21 AM
Rookie's Avatar
I pull my engines and leave the Transmissions in and the drives on. I have Borg Warners, but you should have no problem. Just support the tranny once engine is out.
Rookie is offline
Old 12-10-2009 | 12:10 PM
It could be done but not worth the hassel. Only takes 15 minutes to pull the drive. Rubber tail stock mount is expanded in the transom plate so you wouldn't want the trans shifting around any while removing the engine. Also you could grease your u-joints and tail stock bearing by removing the drive which is supposed to be done every year.You would spend more time making something to support the trans and trying to keep it in place while separating it from the engine.Borg Warners are bolted to the transom plate,Merc trans aren't. Pull the drive (6 nuts and aft trim cylinder pin) then loosen the 6 nuts on the trans tail stock retainer(loosens the rubber mount ring) then pull engine and trans together.That would be the easiest and correct way to do it.
picklenjim is offline
Old 12-10-2009 | 03:19 PM
Rookie's Avatar
Thanks, did not know that. Thats why I stated I had BW's. Learn something new everyday.
Rookie is offline
Old 12-15-2009 | 10:59 AM
Im definatly going to pull the engine and trans together. To take the compression of the rubber mount ring, can i access that through the bellows? do i just losen the nuts on the inside next to the tailstock bearing? I think there are about 5 or 5 nuts on the inside. does anything else need to be removed or losened before engine removal besides the obvious controls, front motor mounts and hoses?
olmako20 is offline
Old 12-15-2009 | 12:50 PM
marinetrans's Avatar
I don't recommend disconnecting engine from Merctrans, when removing motor--1. you can bend/distort a NLA drive plate in the process 2. you can bend /distort the spring on drive yoke/input shaft,when that happens the spring can jump over the washer/o-ring on trans. output shaft,first time you put into gear it will tear out rear trans. output seal.
marinetrans is offline
Old 12-15-2009 | 01:45 PM
Yes you go through the bellows.There are 6 nuts and a grease fitting.That's all you need to do back there.Check that the bearing is good beings you can only replace it by pulling the engine. It's a little easier to grease it while out of the boat,just be sure to tighten the nuts down or grease will come out around the retainer.Before reinstalling be sure to loosen the nuts again and put grease on the rubber ring and in the transom plate hole it goes into. Also don't forget to grease your u-joints
