TRS Gimbal Dissasembly Q's >
Old 12-13-2009 | 12:09 PM
Default TRS Gimbal Dissasembly Q's
Hi All,
I've got the bellhousing and all the bellows off, I need to replace both (port/strbd) lower gimbal bearings. Lower pin cotter is removed. Is there a trick to removing the lower pin? There is a screwdriver slot in the bottom but I see no references to it being threaded.
I am using a bit of heat and PB Blaster. Any thoughts?
When reassembling, is the more available equivalent to the Mercruiser bellows glue?
This may be a stretch, but is there a cross reference to industry standard lower swivel bearings and seals? The Merc stuff is $$ for little parts!
Many thanks for all y'alls help, Randy
bustedbrick is offline
Old 12-13-2009 | 02:29 PM
A bit more heat and PB blaster and I got one of them out and the other one moving. Still the second two questions I have though!
Working now on removing the old P/S setup. Pretty Rube Goldberg esque!!
Thanks, Randy
Old 12-13-2009 | 09:45 PM
spazboz's Avatar
Yes you can get the bearings through an industrial supply. I have a friend who owns an Electric Motor Supply and Service facility, and thats were I buy all mine. If you have any trouble, let me know. I can get them for you. Also, if your have dropped, you will want to inspect your upper bearings/ steering pins/ steering arms. If you need to replace the pins and the arms, that's where the big money is at.
spazboz is offline
Old 12-13-2009 | 09:59 PM
Thanks, I couldn't imagine Mercury tooled up anything unique, I'll let you know if I hit a wall finding a bearing locally.
How (not)important is a loose steering arm if I am moving to external steering?
Thanks, Randy
Old 12-14-2009 | 10:44 AM
Audiofn's Avatar
Charter Member #232
If you are going external it is not important at all. If you want to you can remove the arm.
Put your best foot forward!
Audiofn is offline
Old 12-16-2009 | 07:48 PM
Mbam's Avatar
Offshoreonly Advertiser
Audio, removing the arm is a no-no. You can cut off most of it, or make a spacer to replace it but the nut on top of the arm + the arm thickness + the washer below the arm is what carries the weight and sets the height of the gimbal ring in the transom housing.
Make sense?
Mbam is offline
Old 12-19-2009 | 11:05 AM
Default thread on upper pin - for slide hammer puller
Thanks for all the info. One last upper pin to go. Does anyone know the internal thread size in the bottom of the upper pin? According to the manual there is a special adapter for a slide hammer and I need to rig something up similar. Square pin style.
Thanks, Rand
Old 12-20-2009 | 09:39 PM
Audiofn's Avatar
Charter Member #232
Make sense?
You know I never thought of that and I have never done it myself but I have seen a few boats with out the arms in them..... Good to know however thanks!
Audiofn is offline
Old 12-21-2009 | 05:07 PM
Lofty's Avatar
Konrad makes a nifty little spacer for their own drives but it works just great on the TRS too.
Lofty is offline
Old 12-21-2009 | 06:42 PM
Good info thanks. I think I'll cut one of the arms down a bit and use the other for a drive angle gauge. I'll have 8 turns LTL and I plan on losing track around the dock.
I got both gimbal rings and the bearings are SHOT, non-existent really. Kind of a poor design and choice of materials, IMHO.
Have a great holiday season.
