-3 Imco shorty: who's running one?
Its a very easy and simple thing to put a 3 inch shorty on Mercury upper. A portaband saw a grinder some quicksilver paint. cut the case just behindthe boss for the trim cylinders, shape the cut to look pretty paint it and enjoy. Ive done probably 20 or more.
I am getting a SCX but wanted to try the -3 Extreme just once to compare speed and handling differences, with the size if the SCX lower and the fact I will be 1" lower in the water with the -2. I should start testing in mid March and hope to be all set up by April. If I am happy with the SCX I will sell the SC
Have any pics of what this looks like????
Do you have to raise it?
I was figuring that up to 14.5" prop would be ok. I'd think a mirage plus 27p or29p would work fine at 2" below the pad on my 21sb. Dunno, maybe I'm thinking too much like an outboard owner
I was hoping to see, or hear about what mods have been done to the merc upper for larger prop clearance with the -3 lower, in case I had to go that route.
Even with the propshaft at 2.5" below the pad, you still think that the 3 blade won't be able to do it?
I've been thinking alot about it... and it did work great with the blackhawk drive. I figure thats higher than anything I'm considering, am I way off?
