-   -   does anyone know what this is? LOOK! (https://www.offshoreonly.com/forums/drives-lower-units/222291-does-anyone-know-what-look.html)
buck30 01-05-2010 06:41 PM
this is a drive i picked up today. it looks to be a trs but the lower isnt. is it a speedmaster? any help would be great.http://i891.photobucket.com/albums/a...0/DSC04473.jpg
marinetrans 01-05-2010 08:51 PM
Looks like a Merc 215E or 215H from the mid 70s
marinetrans 01-05-2010 09:18 PM
its a strange critter, the upper shifts into fwd. or rev.---no neutral, the long tail shaft plugs into a clutch disc/like car set-up which provides the neutral. All shifted by a electric shift/servo box all at once, the clutch disc and the drive rotation.
buck30 01-05-2010 09:22 PM
re
ok i just looked close at a trs upper unit i have in the garage. this unit i found today has a pin i comming out of the upper on the other side of the oil pick up. thats the shifter pin?
Boat Tech 01-06-2010 12:41 AM
Any serial numbers on it. ???
tms1155 01-06-2010 02:07 PM
Thats what it is. No doubt about it.
buck30 01-06-2010 04:21 PM
no numbers i can find under all the paint and dirt. looks to be a 215e like said. it has a shift pin just under the yoke.
marinetrans 01-06-2010 09:20 PM
Merc was in bed w/Ford at the time, that drive was mated to 302 and 351-----it let to the design of the MercTrans next,which has Ford parts in it.
picklenjim 01-06-2010 10:28 PM
Yep, that's the 215E. It was made from 1970-72 ' using serial numbers 2909035 thru 2915034. As stated earlier it was a crazy set up with a automotive type clutch for nutral and forward-reverse shifting in the top end of the drive. Easily identified by it's long drive/yoke shaft and shift coupler between the drive and transom bell housing.
The 215H was more like the TRS. It used a hydraulic transmission (probably B-W) with a tailstock like on the Borg-Warner which bolts to the transom plate. There fore it had a short drive/yoke shaft.
1973 the TRS was born using the Borg Warner and then the Merc Trans ll which shared some internal parts from the Ford FMX transmission.
buck30 01-07-2010 12:31 AM
drive
have you ever seen an early trs with the same type of long input/yoke shaft? i think i have seen one.
