ssalpha
Pirate of the Chesapeake
Found a alpha ss .My assumtion is that these drives are shorter than a standard alpha. Top the same bottom shorter is that correct.I mean shorter between input shaft and prop shaft.Thanks for any input. JOHN
actually I think the top is the shorter piece by 2 1/2 inches.
You have to put shorter vertical shaft and shift shaft in the lower case.
I bought the shorter upper and used my stock lower case.
All I had to buy was the top case and the two vertical shafts for the lower case.
All the rest of the parts are the same.
