Bent Skeg
Heating the skeg and annealing the metal works, Use MAP gas and heat it until the paint starts to bubble. Using a oxygen torch you'll run the risk of burning the metal. For real bad bends heat and work as you go. If your unsure of how much heat it takes, try it out on a bent prop blade. They are alot less forgiving. Local marinas have lots of them around.
