Drive depth on ssm #5s >
Old 02-25-2010 | 02:26 PM
tcelano's Avatar
No, I wouldn't go up quite that high with a V. Unless you are running big diameter 5 or 6 blade prop. Propshaft even with the bottom and above is SSM VI / NXT territory on a fast stepped hull.
You could probably get a V setup to run this high with a 4 blade prop, and it might go like a bat out of hell, but it would probably suck getting on plane. Probably best to stay 1"-2" or so below. Try it up 1" on the middle holes, and see how that works. I'm going to try mine about 4" below to start with, and pull out spacers as needed. I only have 17" props pushing a heavy cigarette, so I'll need a little extra depth.
tcelano is offline
Old 04-26-2010 | 11:21 PM
I think a SSM No. 6 trims in further, but my straight bottom Top Gun has zero slip getting on plane. The prop shaft is only 1/4" below the hull, props are 17 x 32 four blade.
It's probably a combination of the SSM No. 4 or 5 not tucking in as far as the 6's..........and the fact the older Guns do not have a notched transom. The notch will allow for higher drive heights.
I also remember Powerplay notched their SSM rigged hulls and kept the Bravo hulls as a standard V hull design.
CignificantOther is offline
Old 04-27-2010 | 07:44 PM
my powerplay has a full length bottom and came from the factory with #4's........
302Sport is offline
Old 04-28-2010 | 12:35 AM
Hmmm........maybe because of the staggered application? Had a friend with a side by side SSM 4 and it was notched.
Old 04-28-2010 | 08:53 AM
interesting......
302Sport is offline
