imco question
Old 03-28-2010 | 04:34 PM
Default imco question
Is a 1:36 lower compatible with a 1:50 upper? What would need to be changed? Any help would be appreciated. Matt
slinger7101 is offline
Old 03-28-2010 | 05:09 PM
Is the upper an Bravo XR?
HighPriority is offline
Old 03-28-2010 | 05:49 PM
Yes it is an xr upper. Sorry I probably should have added that
Old 03-28-2010 | 05:55 PM
The boat is a 1989 28' Scarab Excel with a 540 in it. The dyno was 645hp. The 1:50 that it has now took some damage and I ran across an Imco 1:36 shortie and I was wondering about pros and cons with that setup.
Old 03-28-2010 | 08:12 PM
Might have to re-prop with the 1:36
firehawkcat is offline
Old 03-29-2010 | 04:37 AM
fastlane40's Avatar
To answer your question your ratio will be 1:36.All XR uppers are the same ratio.If you had a Bravo 1 or 3 upper that would change things.
fastlane40 is offline
