imco scx upper with max machine workx lower
imco scx seems to have a strong upper but when coupled to the imco sc lower, the lower might be the weak point. anyone know if the max machine workx billet 2002-x2 will bolt on to the imco scx upper. i believe the mmw lower is a stronger lower than the imco sc and faster than the imco scx lower. any ideas? seems like this would make a good combo if possible.
Other than less case flex from the billet case and I have been told that somehow max worx is using some kind of double bearing set-up on vert shaft (not sure that is a real problem) those bravo lower gears are still a expendable wear item,Smitty
