Arneson Drives
Old 05-17-2010 | 07:33 AM
Default Arneson Drives
I need to understand the rotation of the ASD-6 drives. I have two ASD- 1721 with gears is this what is used as a standard rotation or a counter rotation? I know it counter acts the standard rotation of the motor. This meaning a standard motor turns counter clock wise and the gears redirect the rotation to clock wise so on a triple engine setup would I use one gear drive unit and two chain driven units? So do all props will turn in for best performance?
ken sampson is offline
Old 05-17-2010 | 08:39 AM
U basicly have a RH rotation drive, for a tripple or twin u would be missing a LH.
I think on a tripple it does not matter if the center is LH or RH ?!
I bet Rik can answer all your questions !!!!!
DareDevil is offline
Old 05-17-2010 | 09:34 PM
fountain4play's Avatar
Wait a few minutes I'm sure Rik with Arneson will see your post and give you the answers...
If he doesn't here's their email and phone numbers,
http://www.arneson-industries.com/
fountain4play is offline
Old 05-17-2010 | 09:38 PM
Rik's Avatar
Rik
Offshoreonly Advertiser
While there might be more than one way to skin a cat so to speak, I would put the Starboard propeller as a LH rotation, the Port propeller as a RH rotation and the center engine as a RH rotation.
Looking at photos of the Lambo boat as well as the 50' that was at the Miami boat show this year, that's how they were set up.
Hey Jim!!
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 05-18-2010 | 09:45 PM
Originally Posted by Rik
Hey Jim!!
Hey Rik, what's been going on....always trying to send some work your way....
Hope everything is going good I'll give you a shout soon....
Eddie should have the motors finished, dyno'd and installed next week... Looking forward to getting back on the water...
Jim
Old 07-18-2010 | 03:49 PM
how you been Rick?
Dose arneson sell the parts so a 1721 CCW gear drive drop box can be changed over to a CW chain drive?
Can the 1721's ratios be changed?
Larry
tomuchstuff is offline
Old 07-18-2010 | 11:51 PM
Rik's Avatar
Rik
Originally Posted by tomuchstuff
how you been Rick?
Larry
I can make then Rh or LH rotation.
What'cha got?
Rik is offline
Old 07-19-2010 | 10:56 AM
What'cha got?
I got an old 1721 ccw gear drive.. I read some where the ccw can be up to 15% more efficient but have more cw props. may want to make it a chain... do you sell parts to swap the gear to chain drive if I want to go cw...
thanks Larry
Old 07-19-2010 | 05:01 PM
Rik's Avatar
Rik
thanks Larry
Larry, you come up with some weird **** sometimes. Rotation cannot make efficiency. LH or RH rotation. A single engine boat will, most cases, run better with a RH rotation propeller as it counters the torque (to a degree) of a LH rotation engine.
The drive itself has no limitations as to RH or LH rotation so it can be made to rotate either direction by the parts inside. I have the parts to do either rotation in different ratios.
Rik is offline
Old 07-19-2010 | 10:10 PM
cool very nice to know....
I didn't think the drop box was able to be changed from ccw to cw..
but I am glad it can be done...
sorry my bad
I was reading about duo props or Contra rotating not counter rotating props my bad..
Contra-rotating propellers have been found to be between 6% and 16% more efficient than normal propellers. "
http://en.wikipedia.org/wiki/Contra-rotating_propellers
