Drive Removal with Imco ext. box >
Old 05-21-2010 | 08:13 PM
Perfectmix's Avatar
Default Drive Removal with Imco ext. box
Hello, I was wondering if anyone has experience removing an XR Drive mounted to an Imco Extension box. Also how do I remove the torsion shaft from the coupler. I am pulling motors this week and have no experience with the Imco set up yet. Thanks
Perfectmix is offline
Old 05-21-2010 | 08:34 PM
Just pull it out like on a reg. BRAVO !!!!
It has a longer splined shaft to run thru the box on the IMCO's !!!!
unbot the 6 nuts..take the ram's off the front (prop side), unhook the shift cable in the back of the drive after u pulled it out about 1 " ( tricky ) and then take it off !!!!!!
I would use a buddy to help..just becasue its easyer,,but i did it by my self before too !!!!
Not that hard !
DareDevil is offline
Old 05-21-2010 | 11:19 PM
What DareDevil said. Can be done by yourself, but much easier with a buddy.
bobsbillets is offline
Old 05-22-2010 | 05:37 AM
Perfectmix's Avatar
Thanks, I've removed Bravos before just wasn't sure if I had to unbolt anything inside the Imco box to remove the long torsion shaft. Thanks again for the replies.
