Anyone use All American Drive Service?
#51
I only paid $6500 to rebuild my drive and i had to get a new housing it was so bad.
#52
According to his website, it looks like his phase 4 mod is 8999.00 with a rebuildable case. Personally at that price, I would still go with the IMCO SCX upper, the lower is rarely the issue. It's the upper case, lame XR gears, and clutch shaft, those are the problem areas of a Bravo. The case can be improved by switching to an IMCO SC case, IMCO also makes a stronger clutch shaft, but you are still stuck with the Bravo gears. For the guy that cannot rebuild their own drives, or for someone that has a standard Bravo drive and wants to make sure it's the best a Bravo can be, I'm sure George does a great job. A lot of people seem happy.
Just out of curiosity ThisisLivin, how many hours have you put on your drive so far, and what kind of power do you have in front of it? Being in Cheboygan you obviously boat in Lake Michigan/Huron.
I really wish AADS showed side by side comparisons of what he has done to improve certain parts.
#53
#55
I think a Drive Guardian only solves half of the problem. Its great for rough water and definitely will solve the issue of the prop coming out of the water and shock of re entry. However, it will do nothing to solve the issue of a 700+ hp motor mated to a drive rated at 600 hp. The gears are simply not designed to handle the torque load. They will still fail prematurely.
#56
My gears started pitting under stock power at 420 hours. The gears suck, period.
#57
I agree the XR gears are a problem,,,I have a box full of XR pitted gears in my repair shop,,but I also see a lot of broken and shredded gears from impact at re entry after getting air. ,,thats where the drive guardian helps,,, for big hp SCX is much better.
#59
