trs rams
Old 05-27-2010 | 08:44 PM
Default trs rams
are the internal and external rams interchangable
cig20 is offline
Old 05-27-2010 | 08:57 PM
Don't realy understand this question ?!
DareDevil is offline
Old 05-27-2010 | 10:09 PM
i need a set af trim rams for a trs my old ones are internal lines and most of the ones im finding are external lines
cig20 is offline
Old 05-27-2010 | 10:28 PM
Yes, they still fit !!!!!!!
Old 05-28-2010 | 04:02 AM
No, it is not recommended by Mercury.The internal line style uses the high pressure low volume trim pump.The external line type uses the low pressure high volume trim pump. Mercury states in the manual that using the incorrect trim cylinders will affect trim operation and may cause damage to the trim system. The high volume external type also uses larger diameter lines from the pump to the manifold on the bottom of the gimble assembly.
picklenjim is offline
Old 05-28-2010 | 11:08 AM
Here's a pair.
http://cgi.ebay.com/ebaymotors/TRIM-...item5ad9b2f525
Old 05-29-2010 | 08:37 AM
thanks
cig20 is offline
