Mirage solid hub props >
Old 06-02-2010 | 07:35 AM
Default Mirage solid hub props
I just picked up a pair of Quicksilver Mirage props with the solid hubs, P/N 48-13244-A5-21P and 48-13243-A5-21P. I am going to run these on my Supthen Rumrunner with TRS drives. Does any one know what thrust washers to use and their P/Ns? I currently have a solid hup cleaver an i believe that prop does not require any thrust washer.
Thanks for you help!
olmako20 is offline
Old 06-03-2010 | 07:51 AM
rchevelle71's Avatar
Call Marc at BAM, he can set you straight, I work in a machine shop, and just turned down a regular baravo one to fit.
rchevelle71 is offline
