-   -   changing gear oil in trs drives (https://www.offshoreonly.com/forums/drives-lower-units/232069-changing-gear-oil-trs-drives.html)
mookster 06-06-2010 11:30 AM
just picked up a 84 formula f302 it has twin 7.4 with borg warner trans and trs drives..
i want to change the gear oil... i see the dipstick for it but not the drain plug .
so how do you drain the gear oil???
picklenjim 06-06-2010 12:17 PM
Drain is on the lower port side near the front. Inside the boat is the reservoir with the dipstick on the transom. Drive holds 3 quarts and the reservoir 1. I always let mine drain overnite. Then I put the plug back in and remove the top cover on the drive. Dump in 3 qts. and put the cover back on. Then fill the reservoir to full on dipstick. Quick ,easy and no mess.
I know the manual will tell you to pump it in from the bottom but that is slow and makes a big mess. I wouldn't recommend doing it this way on other drives but I know it works well on a TRS. It's the only way I ever do it.
Audiofn 06-06-2010 04:10 PM
Make sure you have a LARGE screwdriver. You will likely have to go and get one that is big enough. DO NOT try it with a small screwdriver. Once you strip out that drain plug you are in a world of hurt. I don't lift off the top cover like Pick does, I just take off the drain plugs and fill from the bottom and once a little comes out the top plug I put that top plug in and then pump a few more into the resovoir and then top it off from the inside.
Jon
mookster 06-06-2010 04:33 PM
well i finally found them they had so much paint on them they were hidden i had to scrap to find them. thanks
