-   -   Imco And Seaweed (https://www.offshoreonly.com/forums/drives-lower-units/233095-imco-seaweed.html)
TWIN-SPINS 06-21-2010 07:34 AM
Imco And Seaweed
i have about 400ft of seaweeds ,,,that mossie string stuff,,,that floats near the top,,,(beforei get to clean deep water),,,having an imco lower,,,whats the fix ie. some type of screen ,,to keep seaweed from geting sucked up into the drive,,,what have you guys used to stop this,,,
BenPerfected 06-21-2010 09:08 AM
We just let the sea strainers catch the weed.
TWIN-SPINS 06-21-2010 10:17 AM
NO THIS STUFF PLUGGED UP THE DRIVE,,,no water could get thru to the sea strainer,,,with sea strainer your only protected from strainer to engine,,,iam talking about strainer back to drive,,,:eek:
brian41 06-21-2010 11:48 AM
Had the same problem with mine the last 2 years. I am going to weld the slotted hole closes and drill and machine them simular to what merc does on their sportmaster lowers so I can reverse the drive and remove the seaweed like we did with the Bravo lowers.
Jeff P31 06-21-2010 06:34 PM
Had the same problem !! Installed 2 new stock B1 lowers and have not had a problem since. Imco's are sitting in the basement . If you fined a fix I hope you will share it . Jeff
Baja_man 06-21-2010 07:40 PM
Or install a thru hull water pick-up
TWIN-SPINS 06-22-2010 07:03 AM
that seaweed where talking about would plug the thru water pick-up also,,,i would think
TWIN-SPINS 06-22-2010 07:13 AM
yea i hear you,,,,what worked better for me was,,,after i go into reverse and get the boat moving back,,,,i shut down the engines,,,,this stops the sucking of the seapump ,,,which is help holding the seaweed onto the drive,,,seaweed falls off restart up and go:drink:
Philm 06-22-2010 07:22 AM
that CAN work, but just this weekend I was plugged up, not enough to stop all water flow, but enough for me to notice my water temps climbing some, and nothing I could do would dislodge the seaweed. It was all plugged up when I put it on the trailer.
You could just fill a 55 gallon drum with water and run a hose from that to your water pump. Run off that until you are clear of the seaweed....:party-smiley-004:
TWIN-SPINS 06-22-2010 10:06 AM
http://www.twpinc.com/twpinc/control...4X004A0470W36T iam thinking something like this welded over the water intake,,,you would think imco would all ready have a fix by now,,,why drive all the way down the field( imco),,,and not score???
