-   -   removing a borg warner trans help please (https://www.offshoreonly.com/forums/drives-lower-units/234093-removing-borg-warner-trans-help-please.html)
mookster 07-05-2010 10:23 PM
can someone give me step by step instructions on removing a borg warner trans?'
its mounted to trs drives
my bw trans needs rebuilt
thanks
bustedbrick 07-05-2010 10:35 PM
thanks
Are the engine and trans out of the boat?
picklenjim 07-05-2010 11:42 PM
1. Disconnect battery
2.Remove drive and trim cylinders
3.Disconnect exhaust and water pick-up hose and any other necessary hoses includind the fuel line
4.Disconnect any necessary wires going from the hull to the engine
5.Disconnect throtle cable from carb and shift cable from transmission
6.Disconnect motor mounts on each side of engine and mounts on each side of the transmission to inner transom plate
7.Lift engine enough so it clears the engine motor mount studs and then slide forward until transmission tail stock comes out of transom assembly
8.Lift high enough to clear the boat and pull boat out
9.Let the motor down to the ground
10.Disconnect trans cooler lines
11.Unbolt trans fron bellhousing
12.Slide trans straight out
mookster 07-06-2010 08:14 AM
i didnt think id have to pull the motor.... guess i will thanks for the info. will have to get to work thanks
Scarab3DMC 07-06-2010 12:39 PM
You Have To Pull It, No Rear Support Without The Trans Connected, ,
picklenjim 07-06-2010 01:51 PM
And to move it all forward 8-10 inchs to bring the tailstock out of the transom assembly.
