Bravo One Rattling noise >
Old 07-29-2010 | 04:43 AM
Mr Gadgets's Avatar
Charter Member #601
Let me know what you find.. you may have to pm me.. my computer is having a melt down.
Dick
Mr Gadgets is offline
Old 07-29-2010 | 09:36 AM
I have the same problem! Could it be the coupler? U joints? Mine sounds in the outdrive and sounds like 2 gears chattering to me, on mine anways. Guestion is there anyway to get to the coupler grease fittings also? thanks
little d is offline
Old 07-29-2010 | 07:08 PM
Mr Gadgets's Avatar
Charter Member #601
Grease fittings should be on the back of the engine on the coupler metal hub.. Just lean over the back of the motor and have someone hold on to your feet..
Old 07-30-2010 | 08:29 PM
Hey Dick
I ran a series of tests today and here are the results:
1.) Pulled drive and inspected ujoints and Gimbal: all in excellent shape
2.) Pull top cap of drive for visual inspection: no metal flakes , water , damage or marbles
Note: moved prop shaft back and forth by hand and notice what I consider normal gear lash
3.) Ran boat on the hose and tried the broom stick trick: no change
So unless I hear otherwise I’m going for a ride this weekend.
Brian
superboat1982 is offline
Old 07-31-2010 | 09:59 PM
Dick and All,
Went for a ride today and everything seems fine. I really appreciate all you suggestions and knowledge
Old 06-12-2018 | 06:09 PM
35fountain's Avatar
Default What was the issue
I am having the same problem my mechanic ripped the drive a part 4 times and can find anything what was the issue because mine is sounds like there's a guy with a hammer inside
35fountain is offline
