-   -   how do you remove a bravo drive (https://www.offshoreonly.com/forums/drives-lower-units/236304-how-do-you-remove-bravo-drive.html)
sonic28 08-06-2010 06:42 AM
When trying to take off a bravo drive do you have to put the shifter in forward.Help please what else do i have to watch out for.
Knot 4 Me 08-06-2010 07:16 AM
No. When you pull the drive off it will pull it into gear before the jaws let go of the cable. Just remember to unhook the speedo pickup before removing the drive.
Ted G 08-06-2010 07:17 AM
Not really. Once you pull the nuts all loose, carefully pull the drive back. As you do the shift cable will pull the lever from the drive and expose the end, lift the little plate on top of the lever and pull the cable free. Then slide the drive the rest of the way out. When you go back on, just make sure the cable drops back into the lever before you push the drive all the way home.
klaw 08-06-2010 08:21 AM
just remember the hidden bolt on bottom of cavitation plate
t500hps 08-06-2010 08:50 AM
You guys have it all wrong...fill a cooler full of beer and use the phone number of a couple buddies that have done it before. Once they arrive, in 10 minutes the drive will be off, you will have seen how it's done, then you can BS for 4 hours while you drink all the beer.
(and the best part is you can tell the wife you were working on the boat all afternoon!!!)
mike tkach 08-06-2010 08:53 AM
i think he is refuring to takeing the drive off the gimble,no need to split the lower from the upper for that:party-smiley-004:
mike tkach 08-06-2010 08:56 AM
T500HPS,i like the way you think,even better if you tell your buddys to bring some cold beer.:lolhit:
srx 780 08-06-2010 09:13 AM
Last time i took mine off i had shifter in forward position, tac@5100, mph 74-76, came off rather easy when i hit a submerged log at cumberland, damn near threw me over the handle bars:eek::eek:
anewway 08-06-2010 01:15 PM
Well, that's one way to do it. :)
sonic28 08-06-2010 01:22 PM
thanks guy's now i know except I have a better idea watch five girls drinking beer while they take it off.The drive i mean .serious thanks guy's
