drive reservoirs cap >
Old 08-11-2010 | 09:32 PM
crayolacrazy's Avatar
Default drive reservoirs cap
has any one ever taken the red plunger like thing out of a bad cap and used it that way .I ordered one and it might not get it before weekend.
crayolacrazy is offline
Old 08-11-2010 | 11:30 PM
What is wrong with it???
The red valve is a one valve that lets air in and won't let lube out......usually won't let air out either.
Griff is offline
Old 08-12-2010 | 06:06 AM
I was told ,air moves both way .1 of my caps do that the other dont and I noticed the bottle holding pressure
Old 08-12-2010 | 08:30 AM
On mine, air goes in but not out. It always has a slight pressure on it if opened after a long run. I like that action, as that means the drive is also under slight pressure, and any leaks will be out, not water in.
apollard is offline
Old 08-12-2010 | 09:16 AM
bajarick's Avatar
Mine went bad and leaked oil out of it .
If i remember theres 7 lb of pressure
when running
bajarick is offline
Old 08-12-2010 | 12:17 PM
Mr Gadgets's Avatar
Charter Member #601
If you run it without the valve, you will probably spew fluid all over the place, if it gets hot.
Mr Gadgets is offline
Old 08-15-2010 | 09:50 PM
Thanks ,new ones installed
