-   -   b/w velvet drive leaking (https://www.offshoreonly.com/forums/drives-lower-units/239575-b-w-velvet-drive-leaking.html)
8stinger6 09-22-2010 07:59 PM
Hi,
Can any one help me I have a 1986 stinger 312 with the breather valve on the top of the velvet drive is leaking fluid. I replaced it and it still is leaking. any ideas.T
hank You!
Got Freedom? 09-22-2010 10:17 PM
If your transmission is overfilled it will aerate and blow out the vent. Check the fluid when it is hot and immediately after shutting off the engine. If you see air bubbles it's overfilled no matter what the dipstick shows.
GF?
John the Drive Man 09-24-2010 09:32 AM
If it has always done that since day one, there's a fix for it.
If it just started leaking recently, than you are starting to have
internal problems going on inside the trans. This will cause leaking also. A trans. service tech. of all types of transmissons
for over 25 years.
8stinger6 09-24-2010 05:50 PM
Thanks for the info guys, I'll have it in the water this weekend and I'll check for air bubbles.
lookinforboats 09-25-2010 01:20 AM
fyi - i had twin bw 71c's behind 330 trs that blew oil out of the vents from day one. seems 71c's can handle 300hp. dealer installed drive oil reservoirs and hoses from vent to bottles. solved the problem until I upped the hp and installed 72c's. Then no leaks
powerabout 09-26-2010 01:59 PM
That stops the leak but I had a few that pushed all the oil into the bottle and then blew the box and the oil drains back in!
lookinforboats 09-27-2010 06:45 PM
then it would have pushed ALL the oil into the bilge and blew anyway. sounds like internal problems with those few.
