Bravo to Arneson Conversions >
Old 09-27-2011 | 11:52 AM
  #61
Originally Posted by Marginmn
Question, do the ASD 7 bravo conversion kits fit into the bravo drilled holes on the transom or do you need to re-glass the transom and cut new ones?
The stand off box cover the holes. You do not have to re-glass it with the ASD7M. According to the installation instructions for the ASD7M, you have to make the holes a little bigger to fit the transmission. 10 inches wide. Have not done it yet. Still have one more ASD7M to purchase. Waiting on some $$$
UrbanDisturbance is offline
Old 09-27-2011 | 12:36 PM
  #62
Tks for the info guys.
Marginmn is offline
Old 10-11-2011 | 09:57 AM
  #63
Originally Posted by Rik
It covers the holes so there is no need to re-glass the transom.
Rik. I am very seriously considering the upgrade but have no idea how the set up would react on the single step DDC 37 A/T. Do you have any input on the application ? I have never seen one set up this way and the factory has never tested one either so I would be first to do so. Thank you
laszlo01 is offline
Old 10-11-2011 | 10:42 AM
  #64
i just did my boat that had never been done before......and have great results....it doesnt matter if you have no steps 1 or 2 steps or even a notched transom,,, you will go faster and you wont break
47EXCALIBUR is offline
Old 10-11-2011 | 07:31 PM
  #65
Man nice nice......
skydog is offline
Old 10-12-2011 | 03:07 PM
  #66
I understand where you are coming from but you are fogetting that a surface drives is a surface drive. Arneson is not the only surface drive made. Its just the easiest to convert from a bravo, at a great value considering all you get, and its strong!
There are A/T's running #6 surface drives, NXT surface drives, etc. Your boat will love it!
offshorexcursion is offline
Old 10-13-2011 | 12:41 AM
  #67
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
It is not that much of a stretch, if you have a good boat to start with the boat will simply be better. If the boat is not a good boat to start with then there is little any out-drive can do to change that. The AT 37 is a good running boat from what I've heard so I have no fear in doing an application on your boat.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 10-15-2011 | 12:56 PM
  #68
I will have Greg get with you Rik. Thank you
laszlo01 is offline
Old 10-24-2011 | 09:44 PM
  #69
Rik,
I see a used set of "ASD #8A'S THE BRONZE MODELS WITH 10" DROP BOXES 1990 MODEL "
for sale. Could this be converterd to replace my Bravo XR?
mkrytiuk is offline
Old 10-24-2011 | 11:33 PM
  #70
Rik's Avatar
Rik
Originally Posted by mkrytiuk
Rik,
No, not the same drive at all. Those are not counter rotating either.
Rik is offline
