Bravo 1
Based on the serial number its a 96-99 model. Anything special to know about those years? I did find a couple 1.5 ratio drives for alot less. How hard is it change out to 1.65 & roughly what would it cost?
The OL's had the thin floored gears. A new gear kit for X-gears (changing it in the upper) is around $1650. Then you have labor to set them up and some shims also.. figure another $350. That would replace all the parts in the upper. Then you have to look at bearings and gears in the lower.
Hope that helps.
Dick
Hope that helps.
Dick
