Bravo 1 and top RPM >
Bravo 1 and top RPM
Bravo 1 and top RPM
Old 12-16-2010 | 10:52 AM
Default Bravo 1 and top RPM
What's a reasonable and practical max rpm for a standard Bravo 1 with a 1.5 gear ratio if I'm looking for some long life and durability with this outdrive? I'm looking at a '96 Scarab 22 that has the Bravo 1 and a 454. The block froze so the engine is trash. I've got a marinized 400 sbc I built up to go into a jet boat that I can drop in, but am wondering if I need to change cams to better fit this outdrive. Engine should produce about 500 ft-lbs at 4300 rpm, and 490-500 Hp at about 5500 rpm. I don't have any experience with the Bravo 1, and am wondering how fast you can spin it w/o risking problems. Thoughts?
maverick2 is offline
Old 12-16-2010 | 12:43 PM
The B1 will turn 5500 rpm with no problem.
waconda is offline
Old 12-19-2010 | 12:01 PM
Mr Gadgets's Avatar
Charter Member #601
I have spun B1 and B1 with XR gears to 6300rpm. If it is setup right, no problem..
Dick
Mr Gadgets is offline
Old 12-19-2010 | 12:30 PM
What they said.
Griff is offline
Old 01-05-2011 | 02:55 AM
I have a 24 foot baja with a 550 stroker turning 6000 rpm and we did dyno at 6600 rpm at 600 hp yes i know i'm pushing it but it goes 80mph live on the edge lol
cowboy5214 is offline
Old 03-12-2011 | 12:13 AM
I've always been told that 6000 was the practical max... I've spun mine to 6800 ONCE, and on another to 6600 ONCE... Both ended in failure, but I can't necessarily say it was the rpm rather than the excessive power.
lvrepoman is offline
