# V SSM upper drive unit. >
Old 01-26-2011 | 09:29 PM
MSW
Default # V SSM upper drive unit.
I am searching for a damaged vertical gear assembly hub, it does not matter what gear ratio it is. This gear assembly hub is what connects the upper drive unit to the lower gear housing.
MSW is offline
Old 01-26-2011 | 09:36 PM
Call Randy @ Marine drive 352-447-0309
Old 01-27-2011 | 09:09 AM
RMPRam's Avatar
If I'm correct, in my read of what it is you are looking for, you need the front vertical shaft that contains the front spur gear and extends upward to engage the inside of the upper gear. If this is correct, I have a new splined shaft and several used polygon shafts. Contact me and lets talk.
Gary
612-247-7081
RMPRam is offline
Old 01-27-2011 | 09:23 AM
Gary
612-247-7081
Gary looks like MSW is searching for a damaged vertical gear assembly hub, it does not matter what gear ratio it is ..
maybe some kind of research/devel project
