II TR oil pump inner ellement >
Old 01-27-2011 | 02:43 PM
Default II TR oil pump inner ellement
I took apart the drive of that old carver and the inner element of the oil pump is in pieces. Doe anyone have one? where is the most possible place to find one?
gentlecowboy is offline
Old 01-27-2011 | 04:47 PM
Not sure I understand what you mean by the inner element of the oil pump in a TR drive. Always thought the coupler served as a oil pump in them. Is this what your talking about ?
http://cgi.ebay.com/ebaymotors/MERCR...item45ee0b7425
Or are you talking about in the transmission ?
picklenjim is offline
Old 01-28-2011 | 09:05 AM
Audiofn's Avatar
Charter Member #232
I think that he is talking about the tranny?
Put your best foot forward!
Audiofn is offline
Old 01-28-2011 | 10:35 AM
That's what I'm thinking also. Probably a Merc Trans ll. There's a complete one on ebay now that sounds decent for $650. You could easily spend that trying to repair that one. If the gerotor broke up there's probably other issues which caused it and it has probably wiped out the pump housing.
http://cgi.ebay.com/ebaymotors/MERCU...item19c2a4bde6
Old 01-28-2011 | 11:55 AM
I am talking about the oil pump right in the housing towards the engine where the input driveshaft is located not from the gimbal side. There is a star impeller with internal spline that fits on to the input shaft, which is the "inner element" of the pump and the "outer element" which is a ring withe teeth in the inner diameter. When shaft rotates the star turns with the shaft and the outer ring follows and pumps oil for the transmission to operate. This star is broken to pieces.
Old 01-28-2011 | 12:02 PM
What happened is the guy tried to winterize the boat himself to save money and he didn't know that there is the tranny cooler in the transmission. It froze and cracked the copper pipe. The tranny spins free but the star is broken.
Old 01-28-2011 | 12:10 PM
The problem is that it is no longer available.
Old 01-28-2011 | 09:31 PM
OK. Your talking about the pump in the transmission, not the pump in the drive as you said in your opening post. It sounds as if you have the Merc Trans ll like this one on ebay.
Those transmissions were last made in the early 80's. I know exactly what you are talking about. I have 3 of them for parts and have rebuilt several of them. First off though I can assure you the cooler freezing had nothing to do with the pump. The only way that star piece could have broke is from too much movement of the input shaft. The outer ring like piece can not move as it spins tightly in the pump housing which is bolted down tight to the case. Both of those pieces would have to be replaced as a set. More than likely if you just replace those it will happen again. If you move the input shaft up and down I'll bet there's a lot of play in it. The star like piece is probably moving around with the shaft but the outer ring like piece cannot move any. Either the bearing or bushing on the front of the planetary is probably bad. Most likely the bushing. Also be sure there is a pilot bushing in the end of the crankshaft that the transmission input shaft goes into for extra support. This transmission should be totally disassembled and inspected now that it's out especially the bearing and bushing that's right behind that pump. In short the inner element is moving around too much and the outter element cannot move so the inner element breaks. Transmission probably had low pressure from the wear between those 2 parts before it finally broke. This is why I recommended that trans on ebay. Also if you do just look for another trans be sure to designate if it's for a Ford or GM. Different bellhousings. Here is a site of a guy which does these trannys but believe me the parts are high. That's why I say you can find a complete one cheaper.
http://www.kcmarinetr.com/Default.aspx
Old 02-07-2011 | 12:56 PM
I have plenty of oil pump gears. A used inner gear is 50.00. Be certain that you have a crankshaft support bushing for the input shaft. Generally speaking, the lack of this support bushing is a common contributor to pump failure . www.kcmarinetr.com
rufusgrouse is offline
Old 02-07-2011 | 03:54 PM
Veteran: Army
Default tr drives
i have 2 new tr drives if anyone is interested ph#309-925-4620 karl
kgz3 is offline
