gear lube
#31
Just had my drive rebuilt by George at all american drive and he recommended his drive oil, which is 80 bucks a gallon...Im not sure what type of oil it is. It was in a unmarked container and is clear with a slight yellow tint..I am using it so hopefully its good stuff!
#34
I wouldn't be opposed to trying the NEO brand oil as it looks promising:
http://www.neosyntheticoil.com/
As far as the rest of the oils out there and someone mentioning mixing Amsoil severe gear with lucas oil stabilizer: So far that mix has netted the most positive results in bravo one lower gear life in my own personal testing behind a 1000 + hp/1000+ ft lbs of tq. Aaron and Jason at Max machine worxx get the credit for coming up with that oil mix, they have also done exstensive testing and found this to work very well for them.
As far as 80$ a gallon for the Neo oil, if it kept your gears or bearings from failing it would be WELL worth the price. The guys that are running 500 horse power or less that run stock drive oil without any drama are NOT going to understand why anyone would buy 80$ a gallon oil! I will probably try some myself as i am putting a new set of cryoed/isoe'd/treated gears in my lower unit as soon as they come back from processing , Smitty
#36
#38
1 Post
I ran Amsoil Severe Gear in my drive last year with 500efi's the oil was dark but no metal shavings on magnet. I don't put alot of hours on my boat either though.
Running Bravo X drives.
#39
Bobby, have you had many drive failures? You've got some power in your ride, but I don't recall hearing any carnage stories.
If you want the NEO oil, let me know. I'm a dealer for the Bravo Shop & I'd love to help you out.
Hell, that offer goes to anyone who is willing to run it.
#40
He's running #6's with 525's. A mongoloid couldn't tear that package up regardless of what oil was being used.
