gear lube
Old 05-22-2011 | 09:42 PM
  #81
JasonSmith's Avatar
I can get a good look at a steak by sticking my head up the bull's a$$ too, but I typically take the butcher's word for it.
JasonSmith is offline
Old 05-22-2011 | 09:45 PM
  #82
Originally Posted by endeavor1
Wow, your pretty mouthy about all of this. I can tell you that its lowered the temps in my bravos by a long shot but hey, what do I know. I just run around in a 13000lb bravo breaker.
Heat is a bravo drives worst enemy IMO so by reducing it which is exactly what this oil has done for me, I have increased my drive longevity.
Different strokes for different folks bro. If you like your amsoil, run it. We used to run it in our trucking company for years and saw lower trans and drive temps. On the other side of that coin is NEO oil and its blend has been doing very well in bravo based boats, mine included.
No. Not mouthy at all. This thread was started by someone asking about running the 10w-40 motorcycle oil in a drive. And now somehow its gotten twisted to this NEO oil, which by no means am I saying is a bad product, but I would put the AMSOIL up against it any day, and would like more info on it. I just find it kinda funny that you can't find any good info on the product. Supposedly been around since the 80's, if I remember correctly, and no info? Not even a simple data sheet? I'm glad to hear its working great in your boat. There are a lot of really good products out on the market, but there are equally just as many ****ty ones!
07DominatorSS is offline
Old 05-22-2011 | 09:47 PM
  #83
Hey, at least you've provided good substance to this thread!
  #84
Originally Posted by Rebel_Heart
Just broke a couple of lower teeth off. This is after 3 seasons of running 75/90 Royal Purple. Change oil at the end of every season but only put 20 hours/year. The other drive oil looked ok when we changed in the fall.
What have others found with Royal Purple?
Per Mr. Gadgets, Royal Purple with 5oz of Prolong Engine Treatment, I would like Mr. Gadget to chime in on the Neo, now I have a stock package but I have never had an issue and trust Mr. Gadget's experience.
bert4332 is offline
Old 05-22-2011 | 11:26 PM
  #85
Strip Poker 388's Avatar
Rob
Originally Posted by 07DominatorSS
Nope. Not saying that at all, but AMSOIL's motorcycle oils are also GL-1 rated, and have been tested in FZG gear testing, ASTM D-5182. Just saying, some things are made differently than others, and can perform in different applications.
http://www.amsoil.com/storefront/mcf.aspx
still i dont think there motor oil is better than there gear oil http://www.amsoil.com/storefront/agm.aspx
Like they say,teague is prob running the lowest weight oil/lube as its less friction,now also I bet he's inspecting the gears as normal maintance between races,
Strip Poker 388 is offline
Old 05-23-2011 | 07:10 AM
  #86
I agree and I agree. However, this was all about being able to spin 'em that much quicker. Sometimes you've got to give a little to get a little. Thats all. But yes. For absolute protection, the gear oil is the way to go, period!
Old 05-23-2011 | 02:21 PM
  #87
articfriends's Avatar
My lower gears lasted 10-15 hours with royal purple , 20-30 hours with cryo and iso rem,40 to 60 hours with Amsoil with a little Lucas (with the gears treated), I would NEVER run Royal purple in anything truly high performance again after what I have seen and experienced, Smitty
articfriends is offline
Old 05-23-2011 | 02:29 PM
  #88
Originally Posted by articfriends
As far as the original question,running a synthetic motor oil, it is not EP rated that I know of and I do know that GPM tried some in his drive behind 1400 or 1500 hp and the gears lasted about 2 or 3 hours but the set-up work that was done to his drive at the time is questionable, Smitty
The synthetic I am referencing was a 70 wt Royal purple motor oil. Gpm called up Royal purple and spoke with someone supposedly in the know, they told him the GL rated oils (including their own) "held too much heat" in the gears and the motor oil would work much better, I think they forgot about shear strength/contact patch, less than 3 hours later his gears were destroyed. As far as Amsoil MCF, I have no idea or experience, I do know that some synthetics have the ability to over lap in their applications and ratings due to superior formulation. I have heard of guys running 50 wt Amsoil engine oil in semi truck transmissions, Smitty
Old 05-23-2011 | 02:32 PM
  #89
JasonSmith's Avatar
I have the NEO-Bravo Shop RPD in a 40 Outlaw with twin 575's. Tom just completed a 130+ mile poker run and decided to drop the oil to see what it looked like at the same time interval as he normally changes drive oil at.
He reported back to me today that there was zero hair on the magnets and the oil was still clear and smelled fresh. He said that normally the oil is ready to be changed and there is hair on the magnets.
I believe he normally used Merc Hi-Po or Amsoil. I've asked him for conformation on brand.
Old 05-23-2011 | 03:14 PM
  #90
Thats not a 50wt motor oil in the trans'. Its a 50wt transmission fluid.
http://www.amsoil.com/storefront/ctl.aspx
