700hp on bravo I
Old 04-26-2011 | 10:41 AM
Originally Posted by ICDEDPPL
Whats the point of having that much power and having to baby it, worry about breaking it, down time etc...Thats like building a race car and putting a weak 10 bolt on it.
I had a 600SC coupled to a stock bravo, that went boom, then a Mr. Gadgets Bravo.. that went boom (those were crappy ZX gears thou , bad advice), I couldn`t justify spending $14K on a IMCO in a boat worth $30K but after two drives you`re pretty much there.
And with the IMCO at least you don`t have to try to dance on eggshells.
I will only have to baby it getting on plane. I do that now so its no big deal.
SickSation is offline
Old 04-26-2011 | 11:04 AM
Knot 4 Me's Avatar
You can still destroy a Bravo with that much HP in other ways besides coming onto plane. For example, cruising along and then dropping the hammer is also very hard on drives.
Knot 4 Me is offline
Old 04-26-2011 | 12:26 PM
What about a bmax? Bigger upper gear set, larger vertical shafts, cried and treated lower gears and propshaft. Ive had them on two different black thunders and one had 700s in it.
endeavor1 is offline
Old 04-26-2011 | 12:30 PM
BMAX....... +1......
JMS322 is offline
Old 04-26-2011 | 12:37 PM
Out of interests sake what hp. would be safe with a stock Bravo 1X? Just rebuilding a 496ho with raylar forged internals and BP205 cam indicated to be around 475Hp and if I put Dana Marine exhaust kit on should tip it over the 500.
simon1401 is offline
Old 04-26-2011 | 01:03 PM
not sure the actual HP specs but ive always been told its how you throttle the boat is how long they live
Old 04-26-2011 | 01:11 PM
Will a B Max bolt to to bravo housing?
pacalim1965@yaho is offline
Old 04-26-2011 | 02:20 PM
ok i have 718hp with bravo1 drive.so far it has been good. i had 500hpand 600hp with 1680hours on the drive the wore on the bottom case. i take it easy on take off and baby the drive http://www.youtube.com/watch?v=2Kojm...eature=related
bajabob is offline
Old 04-26-2011 | 03:45 PM
SS930's Avatar
If I were 'fixing' a bravo situation, this would be the order of fixes I'd throw at it (other than just avoiding "bravo butt" altogether in the first place)...
1) Arneson Conversion
2) B-Max or Imco SCX.
#1 will be costly, but cures the problem, plus you pick up some speed and gain a cool roaster-tail.
#2 will cost you some speed, but should hold up fairly well. Still not cheap though.
Pretty much anything else will be a costly band-aid, so save your pennies, you're going to be doing it again if you dont go with option 1 or 2.
Selling the boat and picking up something without BB (bravo butt) might be an even smarter move in the long run, but few people will see that as much of an option.
SS930 is offline
Old 04-26-2011 | 04:37 PM
Yes, I have Merc ITS with Bmax's bolted directly to them.
JMS322 is offline
